Temperature Guage Woes
- Paylrider
I changed my engine from a 92 to a 95 K8, the 95 does not have the second temperature sensor, so I drilled, tapped and installed one, now my fan works but the temp guage does not. I changed both the black and green sensor (both used) with no luck, as well as the guage. There are three items in the same area, a black sensor, a green sensor, both double wire, and a single wire sensor, does anyone know which one makes the temp guage work?
- Tunes67
I am pretty sure its the single wire sensor.. others will be able to confirm or deny this though. Hope this helps.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
Yes it would be the single wire one - the others are almost certainly switches - not sensors, even though they may be called "sensors". I think all they do is put a ground polarity to the ECU when they switch. So yes - definitely the single wire one. You can see the "switches" here:
http://www.mx3er.com/Info/1993%20Wiring%20Diagrams.pdf
Figure 4, grid 15A
Figure 4, grid 15A
