Idling and hesitating problems solved?
Locked
JFERRELL20
Post by JFERRELL20 »
I went and got my car looked at yesterday dealing with the idling and the hesitating. I found out that the PCV valve had went bad. So I went to the local Mazda dealer and purchased on, I thought it would only be a few dollars, but turned out to be $21, so I stopped at advanced auto and got one for $2, and took the one back to Mazda. I replaced that in about 3 minutes, and I could tell a difference in the hesitating, but it still hesitated every now and then. So I took it to a local garage and they told me that I needed a new distributor cap, rotor, rotor button, plugs & wires, and fuel filter. They said that that should solve my problems, so I am on my way to NAPA later this evening. Lemme know if anyone has had this problem and how they solved it.<P>Justin
Locked
