Positive Dimmer?
This forum is for topics related to the MX-3 Electrical System.
JPEG
Positive Dimmer?
Post by JPEG »
I have a wire on my MX-3 harness saying that, and it's a different one than 'Illumination'; what's that is supposed to be?
Thx a lot!
JP
PATDIESEL
Post by PATDIESEL »
We need a pic or something. I've never heard of that.. :?:
Guest
Post by Guest »
I am assuming this wire is on your aftermarket radio harness?
Usually the dimmer/illumination wires will be orange in color. Do not connect these wires to anything. Just cap, tape or cut them off.
Explaination: Most factory radios will dim with the dash/gauge lights when the dimmer knob is turned. Obviously this is not a problem because your factory radio was designed to do so and was made to be in your MX-3. There is no standard dimmer voltage from car to car. Your cars dimmer voltage might vary from 1-6 volts as the dimmer knob is turned while another car might vary from 2-12 volts. Because of this I recommend to play it safe and do not connect the dimmer/illumination wires
True story: Just yesterday, a co-worker of mine decided to hook up the dimmer wire in a customers car when installing his aftermarket radio. Usually this would only blow a fuse but in this case it burnt out a resistor inside of the dimmer switch. I replaced the resistor and all worked fine after. 8)
Hope this helps -Joe
Return to “Electrical/Lighting FAQ”
