Sorry, two tone doesn't work nearly as well on modern cars as it does with classics. There is no way that an mx could pull off two tone nearly as well as a ....well corvette for example:
Maybe it's just me....but solid looks better on nearly all modern cars.
Stock 1995 RS - Creek Blue
Car Meanins:
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
Hope he coppied the MX, cause that Stang is ugly...
On the other hand, the colors on the MX look much better eventhough they are only slightly different.
What is the car domain site for this MX-3?
