SRD front crossmember & rear tiebar questions
snellgrove
Post by snellgrove »
I have a completely standard MX-3 V6 at the moment, and I am thinking about a few changes, I've searched the site and there isn't that much on this thing it seems
so how much of a difference does it make,
and what kind of difference? more understeer? or less? turn in better? is it flatter?
also is the rear tiebar a good mod to put on the car? does this increase/reduce understeer/oversteer?
if anyone can shed any light on any of these, i'd be very greatful! thanks!
1997, Silver, V6
papa roached
Post by papa roached »
i got the cross brace, it makes for more understeer, its just as effective as a front strut tower bar
mitmaks
Post by mitmaks »
ive got upper tie bars and rear lower tie bar, although i had my gs tie bar already and didnt notice much difference if any.
