SAFC II question
SAFC II question
would it work on my ecu??? i went through the search engine and one guy said he heard it didnt and i really need to know that b4 i go and spend the money on one and i dont need it..... and if i do end up getting it does it have to be dyno tuned?? cuz im in the middle of butt f**k nowhere and the closest dyno is like 9 hours away so if u guys could help me out on this 1 itd be greatly appriciated
yea
yea it will work and no it dont have to be dyno tuned. You can tune with a airfuel gauge to get you started, and if you got the money a wideband o2 sensor would be a good investment
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
wideband
Wideband o2 sensors are very expensive,ranging anywhere between 300-600 USD you can order them out of jegs or summit. But your stock narrowband will be ok for your base tuning. You really dont need a wideband unless you are trying to tune the car for maximum power.
BROKE DOWN POS
BROKE DOWN POS
ok
isnt that what i said, if you are trying to tune for maximum power and have no access to a dyno, a wideband is a MUST though, tell you exactly what your a/f is instead of just rich or lean.
BROKE DOWN POS
BROKE DOWN POS
