Car won't start
Posted: June 30th, 2005, 11:02 am
by Jarago
This morning my car wouldn't start...95 mx3 RS
it was makin the typical starting noise, but wasn't turning over enough
I have nothing here (just moved here 2 weeks ago) so I can't test the battery or anything, is there another way to test the battery without using a meter? there are headlights on, and my deck will turn on.
I tried gettin error codes, the check engine light stays solid and the oil light stays on solid (dunno if that's normal). Tried resettin the codes, and doin it again, same thing.
just a few mins ago I tried again, and now it sounds like its tryin to guzzle some fuel now, like a bit of a gargle, but still won't start, any ideas that might help me on what it might be, or how I can get it goin?
thank you
Posted: June 30th, 2005, 11:32 am
by Jarago
nevermind, I got it working
thanks anyways
Posted: June 30th, 2005, 1:09 pm
by tw1st3d_cl0wn
Just out of curiosity, what was wrong?
Posted: June 30th, 2005, 2:35 pm
by Jarago
umm..yea, prob isn't solved
car starts now no prob...but when I drive, it just cuts out and boggles down and stalls
something with the fuel line maybe? ahh its driving me crazy, it was PERFECT before today, and now it does this
Posted: June 30th, 2005, 3:28 pm
by Custommx3
u jump the GND to TEN when u checked the codes?
post results if not.
Posted: June 30th, 2005, 3:42 pm
by Jarago
hey custommx3, thanks for the reply
I tried TEN and GND, and it did nothing at all. The car was now idling at close to 0rpms', and would stall after a min, and now it won't start anymore.
I'm rippin my hair out
Posted: June 30th, 2005, 5:57 pm
by neutral
Is the large rubber ribbed intake hose free of cracks, like hairline cracking between the ribs? They can develop and cause unmetered air to enter the intake stream, causing rough idle, low idle and/or stalling. Especially when first giving it gas or as you come to a stop 'cause the engine and intake hose flexes a bit then. Worth checking to rule it out at least. Costs nuthin to ck. and a temp fix can be made with a tight wrap of duct tape around the cracked area.
Posted: June 30th, 2005, 6:02 pm
by Jarago
could it be anything else more major? when the car does start, I can leave it idle..sometimes its at 1000rpm around (that's the usual) and sometimes it drops to like 100rpm or stall, specially if I give it some gas.
I'm gonna check the intake hose right now
Posted: June 30th, 2005, 6:22 pm
by Jarago
no
no cracks or anything. I wish that was it. Looks like it might end up goin into the shop then..god I hate that
Posted: July 2nd, 2005, 10:44 pm
by Dominicanchu_Nmbr1
That happened to me when i first got my mx about a year ago. .
Check not just cracks... keep looking at ALL the intake connections. that happened to me once on the highway doin' like 80... scared the hell outta me.
Posted: July 3rd, 2005, 1:39 am
by Jarago
I check EVERYWHERE on the intake, dont' see anything..
I brought it to canadian tire on friday (canada day) because it was the ONLY PLACE OPEN I could find (not from calgary). They ran a diagnostics as well, with the same result, nothing at all, so they wouldn't fix it
goin to the mazda dealer on monday, but once again, tomorrow morning I'm gonna give it another try to get it working and check out the intake again.
Anything else it could be? and thanks everyone for the help
Posted: July 3rd, 2005, 4:29 pm
by sw-ontarioguy
Try checking your ground on the battery maybe?
