now this is something to lose your mind over !
m92_MX3
Post by m92_MX3 »
ok well my brake lights are on all the time when i have my lights on but the tricky part is this, when the lights are off and i hit the pedal my gauge lights turn on ? now think about that one and see what you come up with because i am at a loss i have replaced the fuse and the bulbs and i think it could be a short but where ? any help would be great
Thanks
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
Grants
BANNED Member
Post by Grants »
Definitely a ground fault. Whats happening is that something isn't grounded properly so when its on the power flow to ground is "feeding back" through other components. Have a look at the relevant wiring diagram on my site under "info" and see where the ground points are for your brake and tail lights. Check them first and if ok, work your way back to the brake / tail lights.
