Piston won't compress on rear brake caliper
Posted: June 18th, 2005, 7:07 pm
by Robotaz
Anyone familiar with a problem just compressing the piston on the rear calipers? I opened the bleeder valve and only get fluid out from the line, not the piston compressing.
Posted: June 19th, 2005, 10:15 am
by Robotaz
I just read that rear hummer pistons have to be turned while they are pushed in. Could this be my problem? Obviously getting the tool from Mazda is out of the question.
Posted: June 19th, 2005, 12:31 pm
by Shades
Looks like you have a case of the siezed piston. This is common over time and use. You can either replace the whole caliper unit or try and rebuild the caliper yourself. You will get fluid out the bleeder valve, but this doesn't affect the piston being stuck.
Good luck.
Posted: June 19th, 2005, 1:09 pm
by Robotaz
Stupid me! I forgot Mazda has a gay-a-- trick to do anything on their cars. The damn thing screws back in. It has notches cut out to grab on and turn the piston by the face. Thnx anyway.
Posted: August 12th, 2005, 2:04 am
by mitmaks
so it has to be turned in? it doesnt just compress back in?
Posted: August 12th, 2005, 3:54 am
by nope-mx3
That`s correct.
Had I seen this before now, I could have told you guys so.
nope-mx3
Posted: August 12th, 2005, 6:29 am
by Gro Harlem
get some needle nose pliers and turn it clockwise while firmly pushing it in.
shouldnt need too much effort actually.
oh and make sure your reseviour cap is REMOVED or it'll be trying to pressurize inside of there, making it near impossible to push in.
If it is a stubborn b----, use some visegrips on the very tip of the piston (try not to grab the boot or anything) and then try to turn it and move it inward...once its free-up some it should move a lot easier.
sometimes rust forms on the outside of the piston and cauese it to be a b---- to move in and out
Posted: August 12th, 2005, 2:45 pm
by mitmaks
so rear calipers are operating only with parking brake and retract back in when its released?
Posted: August 12th, 2005, 6:53 pm
by jaydog5678
mitmaks wrote:so rear calipers are operating only with parking brake and retract back in when its released?
Yes, our type of calipers are called actuating calipers.
Posted: October 19th, 2005, 2:45 pm
by sk8erdude802
Dont feel bad I destroyed a c-clamp trying to compress one of mine and actually took the thing apart before I found out I had to screw it back in...
Posted: October 19th, 2005, 3:20 pm
by Custommx3
You can rent a universal tool that will turn them in fro Autozone if you have on in your area.
Posted: October 20th, 2005, 8:23 pm
by sk8erdude802
I used the end of a adjustable wrench.
Posted: October 22nd, 2005, 9:43 pm
by mx3autozam
OMG guys. I'm new to MX3's and know this
Remove the 13mm bolt on the rear and use an allan key to turn it back in
Posted: October 23rd, 2005, 9:58 am
by Yoda
mx3autozam wrote:OMG guys. I'm new to MX3's and know this
This only works if you have the rear calipers designed for the 323. Some of the MX-3s have genII RX-7 rear calipers which is the type being discussed here. These calipers the actual pistion has to be screwed back in instead of having a retracting screw on the back.
There is a third type of rear caliper that I have seen on a few '96 these are worse that the 323 screw retracting type for jamming and not working. Never actually tried to replaced the pads on one of these. The last time I saw one of these 5 years ago they were so far gone that the calipers needed to be replaced along with the pads.
