Does anyone still use the OEM rear window shade? That "wing like" attachment that goes over the back window to shade the passengers in the back seat? Is this piece available aftermarket anywhere?
Thanks for the feedback!
96 GS, 17" Niche's, Falken 40's. Eibach springs, Tokico S/R struts, Ractive front & rear strutbars. Supertrapp exhaust, K & N intake. Soundstream Reference, JL & Eclipse audio.
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
hatch shade and hatch garnish are two different things, Didlin was selling his on ebay not while ago. I wanted one when I got my SE but now I changed my mind as I think car looks cleaner without it, at least the way the shape is I dont like it anymore, if anyone would;ve made cleaner profile carbon fiber one I wouldnt mind getting one
Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE '95 Cobra SVT #2722 '68 Charger R/T 440 http://www.cardomain.com/id/mitmaks
Just materials. The original ones were made of a smoke plastic, but they haven't been manufacturere for years, so you have to find them used, good luck, they are quite in demand, most people are holding on to them.
Corksport makes a fiberglass replica of them, should availability should be pretty good, the only problem is that you can't get the smoked black look, you would need to paint it, which some who had the OEM shade did.
1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
