Page 1 of 4
Your IDEAL suspension setup...
Posted: June 4th, 2005, 10:30 am
by Shades
So what's the best combination of pieces that will work?
I guess they're different setups for the RS and GS... give me setups for both.
So far I've seen ZX2 struts and Eibach springs...
Posted: June 4th, 2005, 12:29 pm
by nope-mx3
I got a GS, so my setup is for that one.
All the SRD suspension goodies (crossmember, tie bar, bushings etc)
Ground Control
Koni`s
Whiteline rear swaybar
front and rear upper strutbar
Mazdaspeed front upper strutmounts
Probably some other stuff aswell.
What I`d like to know now, is if the ZX2 Ford Racing coiloverkit would fit the Mx3, as the ZX2 struts do fit.
nope-mx3
Re: Your IDEAL suspension setup...
Posted: June 4th, 2005, 1:26 pm
by quicksliver
Shades wrote:So what's the best combination of pieces that will work?
Far as im concerned, stay away from ZX2's. A few people on mx-3.com are now starting to have them blow and/or leak. However, this is currently in debate lol. But ya, just my .02 cents.
Posted: June 4th, 2005, 2:05 pm
by 93SOHC
My suspension on my RS is great. Here's what I have:
Tokico Blue struts
G.C coilovers
Front strut bar
Rear stock Tie bar from a GS
16X7 Motegi's w/Falken 205 40 16's
The only thing I wanna add is a rear strut bar and slightly bigger tires (215 45 16's)
Posted: June 4th, 2005, 4:09 pm
by babyblueMX3
nope's got it all :)
Posted: June 4th, 2005, 4:56 pm
by neutral
When the Tokico's break down, Koni inserts will go on.
Posted: June 4th, 2005, 5:22 pm
by Macen
I've got:
- All SRD bushings
- Red Konis
- H&R springs
- CS rear strut bar
Really satisfied with this setup. Thanks to Nope and all other people that got me in to Konis. :)
Posted: June 5th, 2005, 12:25 am
by Gro Harlem
mazdaspeed or konis
B+G's or H&R's
best
Posted: June 5th, 2005, 1:33 am
by atlantamx3
Mazdaspeed struts, Ground Control Coilovers, Whiteline rear sway bar, corksport front & rear upper strut bars, Polyurethane bushings & those nylatron things that SRD is now offering.
Posted: June 5th, 2005, 4:31 am
by nope-mx3
Oh, I forgot to mention.
I also got helpersprings on the Ground controls.
nope-mx3
Posted: June 5th, 2005, 12:08 pm
by 93SOHC
neutral wrote:When the Tokico's break down, Koni inserts will go on.
Same here!
Posted: June 5th, 2005, 12:12 pm
by Nd4SpdSe
Gro Harlem wrote:mazdaspeed or konis
B+G's or H&R's
best
I love my setup, and thank Gro for the suggestion.
Posted: June 6th, 2005, 9:16 pm
by Shades
Are B+G or H&R better than Eibach springs?
What about the brand DropZone?... doesn't seem so good when you see them on eBay for $99 for the set.
Why would you need shims for GC coilovers?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33582
Apparently they're made by SRD...
Posted: July 19th, 2005, 11:57 pm
by Shades
I having a hard time deciding what to get?
Koni's
OR
Toiko's
OR
ZX2 Struts
I know I'm gonna go for Eibach Springs.
I can get a good deal on Koni's for $180 CDN each for front and rear?... is that really a good deal?
Are they adjustable with a nut on top? All I have found on the website is that you can adjust them only when they are off.
Posted: July 20th, 2005, 12:50 am
by nope-mx3
Koni`s are the best in my opinion.
They are also rebuildable.
nope-mx3
