First autox day
Posted: June 1st, 2005, 6:29 pm
by projectmx
well here is a link posting times for the windy city miata's may 28th autocross day: http://windycitymiataclub.com/autox/aut ... ntune2.htm
this is my first autox and i will be running more throughout the year... can't wait to upgrade my suspension and eventually tires/rims... maybe if there are some other mxers in the midwest interested they will join up
Posted: June 2nd, 2005, 10:33 am
by RaverChankoMX3
Congratz on your first AX!! and not getting the STD
How did your Fuzions run? My friend had em on his M3 and hated them..actually switched to the new azenis. How was the course layout? 70-sec is getting pretty long. 12 runs in a day is awesome! How much did you pay?? I pay 10/event (membership disc.) and we get about 3-5 runs. But then again you only had 27 enteries and a lunch break. Not bad.
What classing system did you use?? Doesn't look like SCCA or NASA..what we normally run here.
I see you ran with #6, any reason? I'm always curious bout why they pick what number.
Posted: June 3rd, 2005, 10:18 am
by projectmx
wow 20-questions
well my fuzions ran pretty good for being a year old and having the tread a bit low plus my alignment is off and the inside of the tires are a bit bald.
as to length yeah some of the guys were telling me some courses they run are only 30 second courses.. the longer one i though is more fun but i have yet to taste the short ones.
miatas used a/b/c/d depending on modifications i believe x1 was a non member or non miata i guess under 250 hp and x2 was over 250. not sure what the actual class system is
i chose number 6 cause the time keeper couldn't see the 1 infront of the 6 cause i accidently put the white side out *i have a white car* otherwise i would have been 16 just cause i have a 1.6L and i couldn't think of another number. and it cost me $20
