sloppy shifter handle 5spd. manual?
rusty
Post by rusty »
I noticed that the shifter on my 5 speed manual transmission has a lot of pay in it. Any idea what would be worn out causing so much play? I wanted to install a short throw shifter what would I need to eliminate all that play.
mxmaz
Post by mxmaz »
you need new shifter bushings. Get the bronzoil shifter bushings on srdperformance.com and make sure you can use them with the short shifter you get.
bmwm3guy
Post by bmwm3guy »
also get the shift extension rod brushing.. makes for some nice tight shifts. I have the bronzoil brushing, the extension rod brushing and a B&M shifter and the car is SO much more fun to drive. :D
Return to “Transmissions”
