Can KLDE internals work on the K8
Juans_93_MX3
Post by Juans_93_MX3 »
Infact, I am wondering, why does everyone here swap there K8s out?
Isnt there anything that can be done to make them fast?
Can they even handle a turbo?
Anyway, I am just wondering, is there a way to put say, KLDE pistons/rods, cam, camshafts or heads in the K8?
Infact, is there anyway, to bring the K8 to atleast 170hp/tq without forced induction?
2008 Mazda 3
1993 MX3 GS
lakersfan1
Post by lakersfan1 »
If you put KLZE cams, KLDE rods and crank, Millenia intake manifold, PAcesetter headers ..... I'm sure you could get 170 crank HP. You can't put KL pistons in because the bore is different. Heads will likely be too wide of valve spacing. But everything else you can swap.
1992mx3
Post by 1992mx3 »
after swaping all those parts would the 1.8 still smog?
1992 MX-3 GS in work.
2006 speed6, Wife say's i can't work on it.
2004 GSX-R 1000 Mat Mladin Replica
2006 toyota tacoma
1995 MX-6 in pieces almost ready for the junk yard, To much body damage.
lakersfan1
1992mx3 wrote:after swaping all those parts would the 1.8 still smog?
Why wouldn't it?
rebel2k4
Post by rebel2k4 »
On this topic somewhat still, I searched but with no luck.
Does anyone have the rod measurements (length, rod big end, etc) of the K8? Thanks
98 Ford Ranger 3.0L
mrspanky79
Post by mrspanky79 »
the rod ends on kl rods are larger then the boar of the k8 so they dont just drop in it takes some costum work and and unusaul way of putting it togethor to make it work.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
Custommx3
Site Administrator
Post by Custommx3 »
if you put that kinf of $$ into it, may as well drop a KLZE in it.
Juans_93_MX3
Custommx3 wrote:if you put that kinf of $$ into it, may as well drop a KLZE in it.
With that kind of money invested in a K8 (which might be a little more than a KLZE), it probably wont have as much as power as the KLZE, infact, probably the same as the KLDE but it should be able to handle alot more power than a KLZE would be able to handle
Not only that, there wont be a need to buy hard to find imported ECUs
2008 Mazda 3
1993 MX3 GS
hgallegos915
Post by hgallegos915 »
Ok im dumb..whats does smog man? smoking ?? kicking azz? aa someone tell me :P
-hec
babyblueMX3
Post by babyblueMX3 »
hgallegos915 wrote:Ok im dumb..whats does smog man? smoking ?? kicking azz? aa someone tell me :P
probably smog testing for emessions ?
RIP 400whp ZE-T MX-3
