Filling Manual transmission with oil?
Posted: May 17th, 2005, 11:43 pm
by rusty
I have a 93 MX3 with a 5 speed and have drained the gear oil by removing the big plug, but not sure where to fill it up. I tryed filling it through the check level bolt on the side of the case but it won't take any oil. I have a Chiltons manual but it doesn't help me much. What is the proper procedure in filling these with oil and how much oil would it take?
Posted: May 17th, 2005, 11:53 pm
by Tunes67
Remove your speedo gear and fill it from there.
Tunes67
Posted: May 18th, 2005, 12:01 am
by mitmaks
Posted: May 18th, 2005, 8:31 am
by rusty
Where abouts does the speedo cable go into the transmission?
Posted: May 18th, 2005, 12:17 pm
by atlantamx3
rusty wrote:Where abouts does the speedo cable go into the transmission?
Uhh Did you even click the link above? It told you EXACTLY how to do it....
Here is the pic anyway because you are lazy:
![Image](http://www.atlantamx3.com/misc/v6trannyfluid.JPG)
Posted: May 18th, 2005, 2:05 pm
by ccreech
