Wiring Harness Differences?
phredren
Post by phredren »
Does anyone know if there are any differences between the 1994 and 1995 B6DE main engine control wiring harnesses? I'm trying to wire up my EManage using wire information from a 1995. I hooked the RPM wire signal up to the 2E pin location, but it isn't showing a tach signal.
Any thoughts?
It's a two plug ECU.
Typhoonk
Post by Typhoonk »
well if you can't find it there. Tach will be a yellow/blue wire at your distributor :D
PM for info
phredren
Post by phredren »
Yellow/blue eh?
Same colours as the same wire in my 1990 Festiva.
Typhoonk
Post by Typhoonk »
you worked on a festiva!!! cool, I wanna get one of those and turn it into a convertable!!! That's my project after I take my welding courses
PM for info
phredren
Post by phredren »
I swapped a B6T into the car a few years ago (2002), this winter I wanted to switch the engine over to use a MAF because the flapper-door type air meter is impossible to tune with on that car. I ended up swapping the MX3 cylinder head, intake manifold with VICS, every sensor, wiring harness, and ECU into the car. I have to wire the tach in the instrument cluster up to the ECU and to my wideband and Emanage... which is why I was wondering about differences in the wiring harnesses. The wire at the pin location which is *supposed* to be the tach signal doesn't do anything for the tachometer...
phredren
Post by phredren »
By the way, I'm just in Mississauga. My buddy JMAC with a soon-to-be-BPT 323GT (which I used to own until I sold it to him) lives out in your area. We should meet up one day and talk about Mazdas :lol:
Typhoonk
Post by Typhoonk »
why don't you come out to a wednesday meet and bring your friend? I'm gonna try and make it next wednesday too
PM for info
