confused.... nub question
so i have a 95 DOHC RS do i have a b6t? or waht do i have im confused by all the other motor codes thanks
95 DOHC 1.6L V4 mx-3, 12,145 miles, ebay intake
you got a b6ZE I believe. Can easily be converted to the b6t(t stands for turbo) though. This whole place was confusing as hell when I first joined, but 7 months later i've got like 1200 posts. Just keep reading man, you'll get the hang of it sooner or later. Welcome!
- monty73741
- Tunes67
Actually.. The B6ZE is the Miata engine.. in a 95 RS he would have a B6DE. Though you could still make it into a B6T. B6T's came in late 80's 323's and early 90's Mercury Capri's.. there is a FAQ in the 4Cyl FAQ that Gro wrote up a while ago. Easily confused though.. I thought my engine was the B6ZE for a while because I saw it listed in my uncles shop manual for 94. But the manual he uses at the shop doesnt distinguish between cars.. It just shows the engines that were available for that particular year. Cheers
Tunes67
Tunes67
- freyguy_412
- Tunes67
Oh heck no.. with a engine that fresh.. you wont have to touch the bottom end.. you could port the head & intake, maybe put a header on it.. but if my engine was that fresh.. I would turbo it.. its a prime candidate for 30 HP worth of boost Though the best thing you could start with is a bit of reading.. do a search on turboing the B6DE.. once you know what you need to do.. then hit the buy/sell forum & e-bay to dig up the parts you will need. Best of luck.
Tunes67
Tunes67
