Clutch
shawno
Clutch
Post by shawno »
I am gettin the KLZE motor for my Mx-3 and i want to get a good clutch for it i was thinkin of a two stage, but will a normal stock clutch do the trick.
mxmaz
Post by mxmaz »
No get an aftermarket clutch. Do a search on here for act, clutchmasters, spec, or centerforce clutches and then decides which one is for you
shawno
Post by shawno »
Are the Clutches for the 1.8L the same for the 2.5L so i could just get a stock 92 1.8L clutch and it will work for the 2.5L
Talon_66
Post by Talon_66 »
shawno wrote:Are the Clutches for the 1.8L the same for the 2.5L so i could just get a stock 92 1.8L clutch and it will work for the 2.5L
Yes, interchangeable.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
solo_ryder
Post by solo_ryder »
Would the stock 2.5L clutch hold up on the KL since the DE and the ZE have about the same amount of torque?
mxmaz
Post by mxmaz »
there was a couple ppl on here using the exedy one on ebay and said it was holding up. And that clutch is only cheap to about $110 and i have heard nothing but good things about it.
Talon_66
Post by Talon_66 »
solo_ryder wrote:Would the stock 2.5L clutch hold up on the KL since the DE and the ZE have about the same amount of torque?
It should. But why not just pay a bit more and get a Stage 2 Clutch?
Macen
Post by Macen »
I have the Exedy. No problem with that one.
But if you are going to do hard launches at strips, you maybe should get an even better one.
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
Talon_66
Post by Talon_66 »
I think if someone bought a stock clutch they'd regret it down the road.
shawno
Post by shawno »
Where can I find a Stage two clutch
vozaday2000
Post by vozaday2000 »
just look for act stage 2 or centerforce stage 2. you could find a performance shop and ask for one or look online. most brands make stage 2 clutches.
