Drive axles
- shawno
Drive axles
Should I get up greated Drive axles for the mx-3 With the KLze motor, will i just burn the OEm's up i tend to spin the tires a little bit.
no but you can
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
most time's you shatter a Cv housing more than shear a axle
if your drag racing install brand new axle's as most cars have done
high milage and the axles are fatigued...
