How Fast is the KLZE
shawno
Post by shawno »
I was Wondering How fast the KLZE will be in my 92 Mx-3 like zero to sixty times and 1/4 times
DavidOS
Post by DavidOS »
anywhere between 14.0 to 15.0 seconds
but when you sit in it 17.0 to 18.0 .. minutes
MX-3 Money
Post by MX-3 Money »
DavidOS wrote:anywhere between 14.0 to 15.0 seconds
GAH? was that a typo? 17 to 18 minutes?
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
DavidOS
Post by DavidOS »
no but a joke maybe??:)
Juans_93_MX3
Post by Juans_93_MX3 »
You should be able to hit low 14s at the 1/4
2008 Mazda 3
1993 MX3 GS
Macen
Post by Macen »
A guy I know with the Mazda MX-6 (KL-DE) does 0-1/4 in 14.3 sec. 0-60 in 6.03 sec. He has a OBX header and 2.5" system with one muffler and without a catalytic converter.
The KL-ZE must be faster than that.
Black '93 GS-RL KL-DE
White '95 RX-7 Type R Bathurst
http://macen.nullnet.com
jschrauwen
Post by jschrauwen »
Previous owner of ZE engine said he got 13.8 for the 1/4.
bigtime
Post by bigtime »
wait til i get my swap.... i will clear this up once & for all !!! : 8)
Gro Harlem
Post by Gro Harlem »
umm...those numbers are BS. I've yet to see anyone on this forum post real time slips. THe only MX3-ZE timeslips I've seen were on ProbeTalk.
And I've only seen TWO that are in the 13's, and thats with heavy mods (afpr, I/H/E, t/b)
Most seem to run 14.2-14.8's.
I haven't run mine in over a year, but the best I've got is a 14.8 which is crap IMO. My goal is 13's but if not, oh well. I'm not going to piss away more money on this crap motor than I already have. I'd rather keep it reliable & BPT the 323 if I want speed
DONATE TO MX-3.COM
Macen
Post by Macen »
Sorry, I forgot the mention that the times were measured with a G-tech. They have tested the G-tech at a strip, and there was not much difference compared to the strip's time measurer.
mxmaz
Post by mxmaz »
Macen wrote:Sorry, I forgot the mention that the times were measured with a G-tech. They have tested the G-tech at a strip, and there was not much difference compared to the strip's time measurer.
My buddy has a G-tech and says its only accurate within 1 second
lakersfan1
Post by lakersfan1 »
Gro Harlem wrote: Most seem to run 14.2-14.8's.
Seems about right. I'd like to get a 13.99 if I ever get my engine running, but would probably need some racing slicks and some other various stuff like nitrous or interior strip to get it. Also not foing to get it in Vegas since it's a half mile up.
hgallegos915
Post by hgallegos915 »
ive seen it.. dont need nitrous for 13.9 just get slicks and a stage 3 clutch an probably redlining the crap out of it :S
-hec
Nallboy
Post by Nallboy »
hgallegos915 wrote:ive seen it.. dont need nitrous for 13.9 just get slicks and a stage 3 clutch an probably redlining the crap out of it :S
That's the typical assumption, but better times come from shifting before redline. You gotta stay in the powerband. 8)
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
Well Gro and everyone else come january this issue will be
put to bed once and for all time slips will be posted along with
link to the nights racing times
I will be in the 12's else there is one serious problem!
