how do you get flywheel off
i have a 92 mx3 gs 1.8 of course. was wondering how do i get the fly wheel off. i cant seem to find anything on it. and thanks for any help or advise
the clutch and pressure plate have to come off then you would see the six or so bolts in the middle that hold it to the crankshaft
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
okay there is still a plate that has to be taken off the crankshaft with the same 6-8 bolts that holds it in place
unbolt tranny,
unbolt clutch
unbolt little flywheel.
unbolt clutch
- JWMX3
wtf ??
then you DONT HAVE A FLYWHEEL
its called a FLEX PLATE...... and you remove it just like you remove a flywheel, just like everyone is telling you except there is 4 nuts to unblot on the back of the torque converter and that comes off first
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
