will a tranny out of my DOHC 1.6 fit a 92 protage 1.8 motor?
i have a friend who is doing the swap for me and he said that it should all bolt up fine cause he's done swaps on these cars before..but i though i would check just to be sure!!
buying modded cars is like dating a pregnant woman...somone else already had the fun!
Yes it should. You'll have to use your 1.6L clutch and flywheel though.
- Yoda
Not necesarily he said it was a '92 Protege and he is from Canada. All Protege's sold in Canada including the LX had the 1.8L SOHC. Only the '90-'91 323/ Protege GT had the 1.8L DOHC. Even after '95 all the 1.8 and 2.0L Protege's up to '03 used the same tranny, clutch and flywheel as the B-6 MX-3s.JWMotorsports wrote:Yes it should. You'll have to use your 1.6L clutch and flywheel though.
