I was able to start my new engine (hooray) but im having a couple of issues due to vacuum leaks.
what is this and where does it attach to?
![Image](http://img.villagephotos.com/p/2005-3/977465/where.jpg)
you see those vaccum thingers under the TB? what goes to it?
![Image](http://img.villagephotos.com/p/2005-3/977465/vacuum.jpg)
That hose with the gray tape, I'm hoping the other end is not disconnected and the end with the gray tape should go to a vaccum spiggot on the IM, I believe. I'm trying to sort similar issues myself post ZE install. Trying to utilize/fudge between K8 vaccum/emmissions layout and Millennia layout. My eye's just go buggy sometimes trying to follow those diagrams. I feel for you M8, good luck!!faried wrote:It's your Purge solenoid which controls your idle. One hose goes to your charcoal cannister and the other to the bottom of your TB. On your MX3 the old Purge solenoid sits just behind the TB on a bracket bolted to the body.
http://www.mx-3.com/95manual/index.cfmgreenstorm wrote:where is the online shop manual on this site? i searched but couldnt find it!
