Slight Drivetrain Shake
My ATX seems to be in very good shape except I have a slight vibration when it shifts into a new gear under moderate acceleration and harder, also on the interstate when going up hills over 65 or 70 mph. "The Pros" don't seem to know what it is. I have a CV boot off on the inside joint on the passenger side, but hear no noise. Also, the car had been wrecked hard enough to bend a wheel and need repainting on one fender. It seems like a bent half shaft would always vibrate. Plz help, i love this car, but it has an annoying ride.
- Tunes67
Assuming you have a well equipped shop.. if you have the parts (Torque coverter/seals/trans fluid.. etc..) at hand and ready to go.. your probably looking at 3-4 hours of continuous work. This is a semi-educated off the top of my head guess since I havent actually changed out a torque converter in a MX-3. Though I have done it on other cars but only on RWD cars. So I would also figure in + or - 1 hour to that guess. Best of luck and keep us posted.
Tunes67
Tunes67
You know what, my explanation of the problem as a shake is poor. After thinking more about this problem i think that i should say for the record that the problem is more of a sustained shudder. Before, i could see mounts being the first thing to come to ppl's minds. I think i'll replace the bad half axle and the wheel bearings and see what happens. At least i won't be getting stranded by a broken CV joint anytime soon. I was wondering if anyone has experience with aftermarket torque converters, if there is such a thing? I'm losing faith with Autozone, Napa, etc. more and more regarding high-wear internals. The parts seem cheaper in quality every time i buy them.
