![Neutral :|](./images/smilies/icon_neutral.gif)
Oh and just so this thread doesn't turn into another "engine swap war", I know about the benefits of the BP swap, and it's still an option for me, just not at this moment...
Thanks!
prototype wrote:Ok I've found some interesting information...
The mazda B6 found in the 323 has the 8 valve head, and produces 82hp which is strictly just called a B6. The B6 found in the mx3 has the only 16 valve head, which makes our engine a B6-2E...
The B6, B3, B5, B6T, and B6D are all the same block, but all have different heads and in the case of the B3 and B5.. different bore and stroke.
Also I'm guessing some water jackets will be different and same with oil passages. So that would be the only reason I can see why other heads from the other B series engines wouldn't fit on the B6-2E.
How closely matched are the exhaust ports on the B6T compared to the B6-2E? What about other motors? I ran across someone who put a ford probe header (2.0) on their car, and they just had to drill a few holes and grind a little more shape into the header's ports...
Yes I'm thinking of turbo charging it. . .
hehe..
92rsmx-3 wrote:does any one know if the 323 sohc motor is the same as the mx3 one?
