How many Litres of 50/50 coolant does it take to fill?
I need to change my coolant. How many Litres of 50/50 coolant does it take to fill everything from totally empty?
Also, in the online-shop manual it says to 'disconnect the oil cooler hoses'....where are these located and what purpose do they serve?
- jschrauwen
Re: How many Litres of 50/50 coolant does it take to fill?
quicksliver wrote:I need to change my coolant. How many Litres of 50/50 coolant does it take to fill everything from totally empty?
Page E2-3 '92 Manual, 7.5Lt, 7.9US qt, 6.6Imp qt
These are the ATX fluid coolant lines that utilize a section of the rad for cooling. Removal required only if you were going to remove the rad, which I believe you are not doing, but rather filling from a dry state, right? Therefore removal not necessary.
- jschrauwen
I don't believe quicksilver really wants to go that way.
First, he said that it was empty, therefore I'm assuming that the engine may have been rebuilt, otherwise he would have said that he had drained it instead.
Second, I would recommend buying the premixed coolant, so it's already at a 50/50 state and there's no need to add water. Costs a lttle bit more, but it takes the guess work out of it all.
Third, hot tap water is not distilled water and poses no significant advantagous because of temp. Bottled water may work, but what's necessary or should I say most beneficial is distilled/demineralized water. It's the minerals that pose a problem to cooling systems as when they are heated and cooled continously, deposits build up in areas within the engine and rad galleries. So much so that eventually these galleries constrict, reducing the amount of fluid allowed to pass therefore cooling capabilities are diminished and engine will be run at a hotter state and cooling fans will run more continously - all in all, a serious recipe for pooching your engine.
Don't scrimp, you've heard the addage - pay me now or pay me later, well ??
Anyway, hope this helps.
- mitmaks
use distilled water, dont use water from your sink, itll leave stuff inside your cooling system
- jschrauwen
