bpt swap problem
bpt swap problem
i swapped a 1995 j-spec bpt gtx engine into my j-spec az3 1995 the fuel pump dosent come on. i didnt use the part of the wireharness that connects to the battery and goes to the fusebox in the engine compartment, i did use the ecu harness. the gtx has abs on it this is wired into the fusebox in the engine compartment if i switch theses fuse boxes will this be a problem
