turn signal
Posted: August 22nd, 2001, 11:30 pm
by cmx3d
i got a question about the mazda mx-3 turn signals. ive noticed that different from other cars ive driven when you make any type of turn the turn signal go's off. now normally it wouldn't be a prob and most cars do this but when i turn the wheel the other way it goes the other way as well as the slitest of turns it go's off and is annoying. i was wondering if anyone else has had this problem and or knows how i can fix it.
Re: turn signal
Posted: August 24th, 2001, 5:25 am
by heatherc
Just wanted to say that I have the same problem...Do ya find yourself putting it back on to finish your turn?? I just put my signal on way ahead of the turn. That way I give the driver behind me enough time to catch it before I go in to my turn???<P>Your not alone,<BR>hgcmx3
Re: turn signal
Posted: September 12th, 2001, 1:23 am
by Guest
I've got the same problem in my 92 gs, hopefully someone will have a fix for it...<P>------------------<BR>-------------------------<BR>1992 Mazda Mx-3 GS<BR>Brilliant Black<BR>1.8L DOHC V-6 5 Speed<BR>-------------------------
Re: turn signal
Posted: September 12th, 2001, 10:41 pm
by white fish
my car, if I turn the wheel to the left half a turn the left signal would go on and vise versa if this is the case<P>you have a bent wheel what you do is put your hands at 9 and 3 and pull as hard as you can<P>------------------<BR>Clear White 2.5L GSR
