Performance loss with bigger wheels?
Hi all,
I recently added these to my '94 1.8 V6 SE:
However, I've noticed a considerable performance loss, especially between 70mph and 110mph - it takes AGES, i mean, literally crawls 1mph per second in 4th, whereas before it would jog through 4th gear. I've noticed it in all gears, but this is the best example, it's really noticable.
Is this normal? I think with the lower profile tyre the rolling radius is approx the same, maybe slightly bigger, but surely this performance hit wouldn't be caused by just this!?!?!
It's getting dropped 40mm tomorrow morning.... (and calipers painted red! )
Thanks in advance,
David
Thanks in advance,
David
Mazda MX-3 Limited Edition
1845cc V6 DOHC
Custom ICE Installation
http://www.destr0yer.net/car-sig.jpg <-- click!
1845cc V6 DOHC
I think how it works with rims is, If you goto a bigger rim, it takes longer for the wheel to do a full rotation which interms slows down your acceleration. And unless you buy lightweight rims, most aftermarket rims actually weight quite a bit more than stock rims. Two factors of which might be causing your problem. Im sure someone else will be able to answer your question better than i can.
Ever notice anyone driving slower than you is an idiot and anyone driving faster than you is a maniac?
01-03 Civic Projector Swap Tutorial
- mitmaks
bigger wheels WILL slow your car down, unless theyre lighter than stock ones or you've done swap/power upgrades, btw 94 SE??? SE's were made only in 93 like mine.
- 93-Spec-Edn
- papa roached
see, now you cant laugh at me for buying 15 inch wheels that weight 10.8 lbs
- mitmaks
25 years in canada, came with heated seats too, american ones didnt but they still made them in US. Canadian ones had sticker on fender with 25th anniversary stickerTunes67 wrote:Just a shot in the dark on the SE topic.. but the SE's in north america were to commemorate mazda being in North America for 25 years right? Well maybe they didnt make it to 25 years in the UK til 94? Just a guess...
Tunes67
Ya, i haven't noticed any performance difference either...
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Ok, the maths is a wee bit off,
But for every lb's of rotating mass F=M*D
On rims its about 1Hp per pound and non stock rims
weight in a lot more.
- papa roached
i noticed a difference when i went to the light 15s, but i also went to a slightly shorter tire to for a bit better gearing
I noticed a huge performance loss when i went with 205 55 r 16 and steel rims..i cant wait till i wear out these tires to go back to 105 55 r 15. I used to be ableto peel out in second gear..not anymore. ..can be contributed to other factors.
-hec
