Throttle Position Sensor
Does anybody know where i can get a Throttle Position Sensor, mine is busted, or so i've been told, and the constant reving is starting to drive me crazy.
Generally how much do they cost and would it be worth it to buy one?
Any help would be much appreciated
92' MX3 GS teal, mazdaspeed air intake, 15' Konig rims...soon to put about 6k into entire car, engine and exterior.
im not sure if the one for probe gt would work..i see why not, make sure its the same as urs also try scapr yards or well new. adjust the one you got, what makes u nthinmk its not working, did u pull codes?
-hec
Re: Throttle Position Sensor
Or so you've been told? You would have alot worse than constant revs.... Something along the lines of the car not starting, bucking, hesitation, poor fuel economy, erratic transmission shifts(if automatic of course). Did you check your pcv valve, vac leaks, clutch spring( if standard of course ). ?mazdaownz wrote:Does anybody know where i can get a Throttle Position Sensor, mine is busted, or so i've been told, and the constant reving is starting to drive me crazy.
Invisible
93 GS Tropical Emerald Metallic MTX 1.8L
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
If your TPS was "busted" you would'nt be going very far at all.
as that tell the comp how far the throttle is open, car might start.
idle, but you put the jandal to the floor you would get nada.....
- jschrauwen
- Aston Wards
- kiwi_MX3
Yea and all donations gladly accepted.....
Anymore lip and ill be down at the south island Nationals
next year to whip your a--.........
adjust it..i did mine yuesterday i ahd the tps code after i adjusted disty timing..then code went away..also when your tps is bad,,doesnt the car run in test mode? and it shakes alot.. well at leats thats what happen to me when i drove without the conector once.
-hec
- Aston Wards
- jschrauwen
Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....Is it done yet?.....jschrauwen wrote:.........So what's the verdict mazdaownz. Was it the TPS or not? Did you get the revving situation sorted?
- kiwi_MX3
Nooooooo....... Not the Mighty Lazer all 60hp at the front wheels....
Actully busy with the new body shell, stripping and panel beating..
- Aston Wards
- jschrauwen
