Dropzone Coilovers
Dropzone Coilovers
has any1 used these coilovers???
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
are they any good???
thanks
thanks
- freyguy_412
your going to still need a good quality spring imo. i made the mistake of going the cheap route and bought the dropzone lowering springs, not the coil overs. the ride really didn't improve, those springs are way too damn soft. and it lowered my car about 1.5-2 inches in the back, but almost non in the rear. I've tried all kinds of s--- to get those springs to settle but my car sits like a god damn meat head hotrod right now. die dropzone die
It might be slow, but it's not a civic!
- Flashpoint2
Yeah, it`s real easy, do it yourself, and save a bunch of cash
1. loosen lug-nuts.
2. jack the car, and put something underneath to support it.
3. remove the 2 clips (brakehose & ABS wire)
4. remove the 4 (8) nuts on the struttower (15mm wrench)
5. remove the 2 bolts on the strutbody (2 17mm wrenches)
Voila everything is loose. Now just compress the spring with a spring compressor, and loosen the top nut, uncompress, compress the new spring, replace strut bearing (cheap, so it`s definetely worth it).
Install the new spring, and do everything in reverse.
6. get it aligned properly
7. Enjoy your new sportier car
nope-mx3
1. loosen lug-nuts.
nope-mx3
not to get off topic but where can you buy the h&r's ?
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
