RedLine
- papa roached
dont post 2 threads in different areas, they will get on you about that, i already answered in the other thread
- atlantamx3
yeh the SOHC's redline is so boringly low... best part of a BP? 7000 rpm redline! (soon as I get mine running right )
my cardomain site: http://www.cardomain.com/memberpage/793483
