motor mount quandry (is that the right word?<<)
Posted: February 15th, 2005, 7:11 pm
by JWMX3
is it possible to remove the rubber out from the metal bracket ?
I have 2 front motor mounts and one has a damaged bracket and the other has a good bracket with cracked rubber..... i wanted to take the rubber from one and put it in other bracket.... but for some reason im doubting i'll get the answer im looking for
![Confused :?](./images/smilies/icon_confused.gif)
Posted: February 15th, 2005, 7:28 pm
by lakersfan1
no
Posted: February 15th, 2005, 8:15 pm
by JWMX3
shocking
off to the wreakers...
Posted: February 15th, 2005, 10:03 pm
by yvan
yes, u can.. i have done it so so many time at work.. get a bearing or ball joint press, find the right adaptor, and bingo.. press that old nasty rubber bushing out. but i think you're better off getting new one..still its only a matter of finding the right adaptor. go here for all your tools needs professional or not, this is the best place to buy professional tool
http://thetoolwarehouse.net/shop/TTW300.html
Posted: February 16th, 2005, 8:43 am
by ccreech
How about polly filling the cracked one????????
Posted: February 16th, 2005, 5:14 pm
by JWMX3
yvan - thanks for the reply,, i will look into that for sure
ccreech-- i was gonna fill the mounts anyways but i cant do the cracked one because its too bad,, the whole center where the through bolt goes is almost falling right out
Posted: February 16th, 2005, 6:47 pm
by Gro Harlem
two of my 4 mounts were cracked completely in half and I still was able to fill them and they've been holding up fine. Just make sure you don't do a half-azzed job of filling them if you do decide to reuse yours
Posted: February 16th, 2005, 7:00 pm
by JWMX3
Gro Harlem wrote:two of my 4 mounts were cracked completely in half and I still was able to fill them and they've been holding up fine. Just make sure you don't do a half-azzed job of filling them if you do decide to reuse yours
thanks Gro, I'm gonna give that a shot ... now i just need to get some 3m windo weld from NAPA
exciting times... i wish i had 2 mx3's to work on
![Idea :idea:](./images/smilies/icon_idea.gif)
Posted: February 17th, 2005, 11:32 am
by Zoso124
And do a little at a time, if you totally fill one up it will never dry or will weeks later. Ya I know its a PITA cause you need your car back, but when I did Barry's I pumped them full and then stuck them in the oven for 8 hours and the insides were still soft. I guess you can hope they harden up on the car but you might squeeze it out before it has a chance to harden fully.
Posted: February 18th, 2005, 1:54 am
by Gro Harlem
and buy a reinforced caulking gun, not some cheapass 2 dollar one. I bent the one i bought in half b/c the urethane is hard to squeeze out.
ALso, put the urethane tube in a sink full of hot water for a few minutes so it flows better, makes it SO much easier
And yeah, don't fill them up at once. I did mine 1/3rds at a time and let them dry 24 hours between filling them again. I left them next to my heat register on the floor so they'd dry overnight.
