BP Swap: pulling tranny w/ engine out
now that I've finally got my engine out of my car (emphasis on FINALLY) I need to see how to go about pulling the transmission out (yes I know I should've pulled the tranny and engine as a unit.... blah blah blah)
anyway, I need to know:
1. what I need to remove from it (I know about the clutch release cylinder and speedo gear, need help with the axles and everything else)
2. what's the best way to pull the tranny? drop it down with a jack? hoist it with chains?
3. I'm installing a stainless steel clutch line... what's involved with removing and bleeding the iold line, installing the new one, and setting that all up?
- ryanlindenberg
i'd take the tranny out the top..should be really easy with all the room. you also need to disconnect the reverse light switch from the tranny.
to remove the axles:
take off front tires
remove the big lock nut from the center of the hub
remove sway bar links
remove lower ball joint bolt
pry lower balljoint from the hub
by this point the shock/hub should be hanging there by the shock tower, it should be relatively easy to move the assembly back and forth.
pull the assembly outward while applying pressure on the driveshaft. you can also tap it lightly with a hammer...don't mess up the threads though. remove the end of the driveshaft from the hub. now you should just have the one side of the shaft in the transmission. you have to pry that one out
it sounds kinda hard but it isn't too bad. good luck.
oh yea and about the clutch line... separate the stock clutch line from the metal ones...all you need is a small wrench. there are also 2 clips that have to come off, pull them off with a plyer or pry them off with a flat screwdriver. to install the new one just reverse my directions above. then you have to bleed it...it's just like bleeding brakes. this is the way i do it: buy a clear plastic hose that will fit on the bleed valve(any local auto parts store), with valve closed have someone pump the clutch 3 times and hold it down on the last one...open the valve, then shut it again(you should hear a little bit of air being released)...with the valve shut have your friend pump 3 more times and hold on the last...keep pumping and opening/shutting the valve like that and it will eventually get all the air out...
MAKE SURE THAT YOUR BRAKE FLUID RESEVOIR DOES NOT GET LOW WHEN YOU ARE DOING THIS...IF IT DOES YOU WILL HAVE TO START ALL OVER AGAIN BECAUSE AIR WILL BE ALLOWED INTO THE SYSTEM.
the reason for the clear plastic tube is that you don't spray brake fluid everywhere and you can tell when the system is free of air when you can't see bubbles coming out.
hope that helps.
hope that helps.
CARDOMAIN WITH UPDATED PICS
helps a little, thanks... I'll have to do that stuff when I get back from visiting colleges today and tomorrow.
One thing that I'm interested in is that the shop manual doesn't say anything about removing the axle nuts at all... it seems that when the assembly drops down, it takes tension off the axles and that allows you to pull the axles free of the tranny. Well, I'll try taking off the axle nuts anyway.... they're really stuck on there
My dad and I broke a breaker bar trying to pry the driver side nut off. Now we bought a giant, meaty bar and about 5 feet of tube for a cheater bar... that should do it![Smile :)](./images/smilies/icon_smile.gif)
Some guy said the nuts have something like 200 foot pounds of torque on em.... damn that's a lot. Unfortunately I don't have access to a pneumatic ratchet.
- David Witherow
yeah you really have to use alot of force to get those nuts off but once you do....just pull the nut off take a ball peen hammer and a small sledge......first tap the axle with the ball peen till its almost out, it will be flush with the hub then turn the ball peen over so that the round end is against the end of the hub then hit the other side with the small sledge till the axle drops out.
- atlantamx3
yeah, those axle nuts are real bastards.... I'm gonna blast em with the wrench after my parents get back from church.... in the mean time I need to unhook the speedo gear, clutch slave cylinder, and the shifter rod + stabalizer.
I'll be SOOOO happy when the tranny is out...... it's the only thing holding me back from my swap![Razz :P](./images/smilies/icon_razz.gif)
