My Projecter Project.
Posted: February 12th, 2005, 3:33 pm
by SE-Man
Well it looks like TomsMotorsports has changed brands lately. I've had to do alot more cutting both on the car and the lights. All I hve left is mounting & wiring then cleaning. I actually cut the Body kit to get a better fit. My lights also came with a wireing diagram. Middle lights are Low beam, inside ones are high beam and outer ones are turn signals.
Posted: February 12th, 2005, 11:00 pm
by SE-Man
Her's the pic of my fitting,
I'm finished now. All thats left is for me to adjust the low beams, and wash the car.
Posted: February 13th, 2005, 12:29 am
by mitmaks
Looking good, post some more pics and bigger if you can
Posted: February 13th, 2005, 1:02 pm
by SE-Man
Finished
This is early morning after I washed the car, it was about 35o. I'll try to take an afternoon pic somtime.
As you can tell, I changed the inside corners from round to a point, to give it a more aggressive look. The hole thing took me about a total 4-5 hours. A whole day of work including changing out my hub and wheel bearings.
