a simple question about KLZE motor
If i would get a KLZE would i be able to use the same intake and spark plugs and wires and perty much any moddes for a K8 motor, can the be used on a KLZE or would i need different moddes?
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
![Image](http://i7.photobucket.com/albums/y296/Legato626/supra%20pics/P1010277x-1.jpg)
- babyblueMX3
yes you can but I would suggest changing them. IIRC the klze uses one range colder in sparkplugs. intake would go but I wouldn't do it because of how restrictive it is and has 180cc injectors instead of 220
RIP 400whp ZE-T MX-3
- babyblueMX3
why would that be ? my ze came with ngk plus one cold range lower than stock ones
- XxantwawnxX
i run normal ngk in mine.
- papa roached
BKR5E plugs
Here's an excerpt from Probetalk about it:
Probetalk user Sehpiro, used the ZFR6F-11 plug, and heard some kind of ticking noise. When he took the plug out to inspect, the r shaped peice that hanges over the ignitor part was mashed into the plug. Therefore the piston had been hitting the plug, cuz the ZFR6F-11 plug is too long, however i do not see how howlett, is safly running that plug in his KLZE. Strange.
- babyblueMX3
IIRC the one I am using are BKR7E-11.. but I'm not sure. I still have the old box of the SP in the garage. I'll take a look tonight
