Turbo Injectors
Nomad_69er
Turbo Injectors
Post by Nomad_69er »
Would RX7 injectors work in a 95 MX3 RS? Turboing the B6 motor and looking for 440 cc injectors. If anyone can help it would be greatly appreciated! Thanks!
here's the link:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
DavidOS
Post by DavidOS »
goto corksport.com
they have stuff for the 4 cylinder models turbo applications ie rods, rod bolts etc.etc.
BuGS
Post by BuGS »
I also have a set of (4) 440 cc RX7 injectors looking to sell. And just like the ones on ebay they are low ompedence so you will need the resistor box. PM me if you are interested.
cjthor
Re: Turbo Injectors
Post by cjthor »
Nomad_69er wrote:Would RX7 injectors work in a 95 MX3 RS? Turboing the B6 motor and looking for 440 cc injectors. If anyone can help it would be greatly appreciated! Thanks!
here's the link:
Those injectors are HUGE. How much boost are you looking for? I have 310's and am running 12psi pretty easily on stock internals. I have a set of 370's for spares.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
JWMotorsports
Post by JWMotorsports »
They work fine with a Super AFC...ecept for idle...idle will be pretty rich! Thats what I was running on my B6t...now I'm going to 96 lb/hr. (1000cc) per cyl.
Nomad_69er
Hey cjthor, you wanna sell your second pair? Are they a perfect fit into the B6 motor? Let me know how much you want for the injectors. Will 300 or so cc injectors work fine with 7-10 pounds of boost (for the time being)?
Thanks again!
Bryan
Return to “Forced Induction”
