This may sound like a completely noob question, BUT:
I had the car on jack stands today working on the intake manifold and started it up to check for leaks and such. I put it in neutral and got out to see both wheels turning. Confused i reached in and moved the shifter around making sure it was in fact in neutral (which it was), got out and they were still spinning. it was easy to stop them from spinning with a foot but they were moving at a pretty good clip. Is this normal?
Wheels turn in neutral?
- Shady469
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
- papa roached
yea, normal thing
- ryanlindenberg
the clutch is supposed to grab when you lift your foot off it...
my wheels don't spin when mine is in neutral though...
CARDOMAIN WITH UPDATED PICS
