hey guys,
i pulled the codes this morning and it just kept flashing 24 (RHO2S inversion error). basically the O2 sensor is shot? is there a way to test it and where is the right hand O2 sensor? also, if it just keeps flashing that one code, that means that that is the only code or do i have to do something to see the other codes?
anyways, any help is much appreciated. thanks in advance.
kevin
93 mx-3 gs
http://members.rogers.com/kovenden/
O2 sensor and codes
- ovendenk
O2 sensor and codes
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
![Image](http://ca.geocities.com/ovendenk/pics/Other/sig.jpg)
All the codes will flash in one sequence. If 24 is all you're getting, that's the only problem. Just get a universal O2 sensor locally. Ask for the one for the 1993 Ford Probe GT 2.5liter. Thier sensors fit fine, but cost half as much as the MX-3's universal sensors. You'll have to clip your old sensor off at the sensor and solder the new universal one on.
Right sensor is your rear one.
