Have any of you done this install i just got mine but there unlike the ones ive seen b4 they all connect at one terminal that goes over the negitave battery terminal. Any info would be appreciated
THX
Ground Wires
Ground Wires
Drive It Like You Stole It.
Have a look at Gro's how to here
http://www.projectmazda.com/howto/groundwire/
In your case you can either use the terminal that came with the kit and run each wire back to that or do it the way Gro did. Or a combination of both. Either way you should get the same result.
