Re: Who makes gaskets?
Posted: August 21st, 2001, 5:03 pm
by JFERRELL20
hey go to advance auto, i have to order one from there very soon, it is approx a little under$40. my valve pan gasket is leaking also<P><BR>justin<BR>
Posted: August 21st, 2001, 6:38 pm
by Guest
At autozone they sale Felpro brand rubber gaskets for the V-6 and they are like $7 a gasket.
Posted: August 22nd, 2001, 3:37 am
by jfbourgault
It's better if you also change the bolts or nuts on top of the valve cover gasket( about 11, i'm not sure, really not sure how many!! :¬) ), since they will probably start leaking again soon after you replace the valve cover gasket, it's a little bit more expensive, but worth it!<BR>the front gasket is not that hard to change on the v6, but the rear one is a b---- and takes time!<P>------------------<BR>
