remove Y pipe to pull engine...
JWMX3
Post by JWMX3 »
It is necessary to remove the y pipe at the cat and take it right out in order to remove the engine ? I just have it disconnected at the headers at would just like to leave it if i can because the 2 bolts on the cat are damn tight and i dont have a compressor yet, unfortunatly :(
babyblueMX3
Post by babyblueMX3 »
you could pull it out but it would be much easier to take it off...I took the 2 bolts off the cat with an electric impact..borrow one from a friend for 5 min. and take those out
RIP 400whp ZE-T MX-3
mrspanky79
Post by mrspanky79 »
just undo the y pipe from the headers and you will be fine.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
babyblueMX3
that's what he did
JWMX3
Post by JWMX3 »
ok i guess i'll try and get my hands on an electric impact if i can and if not, just have to manouver it out with the pipes still in :x
mrspanky79
Are you pulling the motor up and out of the engine bay or are you dropping it thought the engine bay. If you going out the top the y pipe will not get in the way no need to go to the trouble and taking it off. If you dropping the motor out then yes it has to come off.
99 vitara 4x4
