Ze cams and pistons
Ze cams and pistons
Hello everyone. Where can I get 10:1 or 11:1 pistons for the kl engine? Where can i find cams that are a step above the ze cams? Ive searched the net left and right and came up short. Any ideas?
- babyblueMX3
10:1 pistons are stock ze pistons. you can get 11:1 pistons from czt (cyborgzero.com)
as far as cams goes..you can get them from either interprep, cyborgzero, have them reground by Mike Selli, colts cams
RIP 400whp ZE-T MX-3
- babyblueMX3
well no the czt 11:1 pistons won't fit in your 1.8. the k8 bore is just too small...maybe you can get custom ones made for the k8
http://www.cyborgzero.com/
11:1
and i have a set of Kfze cams forsale, they are soposively the most aggressive set of cams that came in the K series motors
11:1
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- babyblueMX3
babybluemx3 wrote:well no the czt 11:1 pistons won't fit in your 1.8. the k8 bore is just too small...maybe you can get custom ones made for the k8
For the price, just buy a KLDE or KLZE and swap in the pistonsncmx3 wrote:I understand the bore is smaller. Can the 1.8 be bored out large enough to fit the klze pistons? How much for the ze cams?
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- babyblueMX3
I don't think the k8 can be bore the kl specs without resleeving
It's cheaper to buy a used complete ZE than it is just to buy aftermarket 10:1 pistons.ncmx3 wrote:I understand the bore is smaller. Can the 1.8 be bored out large enough to fit the klze pistons? How much for the ze cams?
91 Eagle Talon Tsi AWD *RIP*
