Times?
Posted: January 19th, 2005, 3:10 am
by 93SOHC
What happened to the time stamping on the post? they disapeared? :(
Posted: January 19th, 2005, 7:50 am
by MX-3.com
I see them, I recently made a small change to the format of the timestamps on the Forum. Go into your profile and select the appropriate timestamp you would like to use from the drop down menu.
Let me know if the problem persists.
(Topic moved to Site & Forum Recommendations and Issues Forum)
Posted: January 20th, 2005, 11:30 pm
by mxmaz
Yeah i am having the same problem. I have tried setting my profile time to my local time, and that doesnt fix it. :help:
Posted: January 21st, 2005, 12:43 am
by 93SOHC
me neither, i've changed my time zone a # of times and I still see no times on my posts, what up Jeff?
Posted: January 21st, 2005, 9:22 am
by MX-3.com
You should have two settings for time in your profile.
The first is for timezone. The server is at GMT -6 Hours, you should change that to whatever you are.
The second settigns is Date Format: This dropdownmenu has a number of choices for date format: some have datestamps, some have datestamps and timestamps. Some are 24 h our clock, some are 12 hour clock.
Let me know if your still having troubles with it after checking again.
Posted: January 21st, 2005, 10:08 am
by mxmaz
OK, i got it now. Thanks.
Posted: January 21st, 2005, 1:54 pm
by 93SOHC
rock on, I got it
