Leaking oil around distributor
Posted: January 17th, 2005, 12:53 am
I did my BP swap last summer. Never replaced the distributor that was on it.
I cleaned my engine bay at the same time as the swap (not super clean, but I cleaned all the oil from my SOHC off of it).
about three months later, I noticed oil on the top of my tranny? kinda weird. I looked all over - kept cleaning the motor and checking to see where it was coming from.
Today me and a friend took out my distributor cause I noticed that my bolts that hold the disty on were oily. Popped out the disty and noticed oil everywhere. So we cleaned it up, made sure the surfaces were clean and used a little RTV sealant around it.
So I cleaned up the engine again. And hopefully I will not be losing any oil anytime soon.
Was wondering if anybody had oil leaks that the found and stopped? And suggestions I can use to check some stuff
thanks
thanks
