handbrake cable adjustment
sloggy
Post by sloggy »
how does one adjust the handbrake? I can't find anything to tighten???
Joey's mx
Post by Joey's mx »
You do it right at the handle!! Take off the plastic covering the handle and there will be a cable with a nut that is attached to the handle..just tighten the nut and that will make the e-brake tighter!!! Good luck!!
