E-Manage Help
Posted: January 4th, 2005, 7:11 am
Does anyone know if all the features of the E-Manage are compatible with the 1994 DOHC 4 cyl MX3? I know it can modify the signal for the air flow meter, like an SAFC, but can you use the timing retard/advance feature? And if so, which wire on the ECU needs to be connected?
Thanks guys.
Thanks guys.
