can this be done? if so how... i did the thingy where u move it 7 ticks, and it still doesnt idle right, and when i press on the accellerator it chokes.... i know this isnt right heh.. and how do u connect the intake hose to that massive end, i know the stock mx-3's is 2` and this one is 3`....
any info would be cool, even if its to an article heh
RX7 MAF on 4cyl engines
I am going to do this swap this week.
I've had the thing for quite a while, and just haven't had the time to go buy a new silicone interconnect. I'll be using aftermarket aluminum tubing... I don't think you should even try connecting the stock tube to the maf.
I'll tell you how it goes if I get around to it...
