Hi guys, I don't own an MX3... I just have a few questions about them. What year MX3's came with the DOHC 4 cylinder (I'm in Canada, if that helps)? Is this a B6 engine or is it a BP? Do all 4cyl DOHC cars have a VAF air sensor (flapper door) or do they use a MAF? Do they have a knock sensor? And are the cars without the VAF style air sensor OBDI or OBDII?
Thanks guy, I really appreciate it.
4 Cyl DOHC Question
- neutral
Re: 4 Cyl DOHC Question
phredren wrote:Hi guys, I don't own an MX3... I just have a few questions about them.
Q. What year MX3's came with the DOHC 4 cylinder (I'm in Canada, if that helps)?
A. '94+
Q. Is this a B6 engine or is it a BP?
A. B6
Q. Do all 4cyl DOHC cars have a VAF air sensor (flapper door) or do they use a MAF?
A. MAF
Q. Do they have a knock sensor?
A. No (for OBDI, not sure about OBDII motors)
Q. And are the cars without the VAF style air sensor OBDI or OBDII?
A. OBDI for '94 & '95, OBDII for '96 only
- Josh
92-93 is OBD 1, 94-95 is OBD II. 94-95 has a 3 wire O2. and not totally sure about 96, but i know it has i think 2 O2 sensors and the ecu is way different than 94-95.
- jaydog5678
No Mx-3 sold in the U.S was OBD-II. Only the Canadian Mx-3 from 96 was OBD-II. All cars had to be by 96.Josh wrote:92-93 is OBD 1, 94-95 is OBD II. 94-95 has a 3 wire O2. and not totally sure about 96, but i know it has i think 2 O2 sensors and the ecu is way different than 94-95.
The number of wires on the O2 sensors have nothing to do with being OBD I or II.
