Turn signal stick has fallen out of the steering column.
morcheeba
Post by morcheeba »
Anyone have an idea of how to fix this?
It became 'loose' (didn't seem as stable as normal) and then eventually just dropped to hang on a downward angle. It has since totally fallen out of the steering column and is hanging on by the wiring. If I put it back into the column, I can still turn, but it just continues to pop out.
Is this something I can fix myself, or ...?
It works otherwise, but the darn stick has just fallen out.
Thanks.
mitmaks
Re: Turn signal stick has fallen out of the steering column.
Post by mitmaks »
check local junk yard for new one, shouldnt be expensive and easy to install
